Voor het instellen van de gas standen heb je geen Castle link nodig. Voor eerst onderstaande uit dan zal het al een stuk beter te regelen zijn.
How to Calibrate the ESC
STEP 1: Start with the transmitter ON and the ESC switched OFF and not connected to the battery.
STEP 2: Plug a battery into your Castle ESC.
STEP 3: Hold full throttle on the transmitter and turn the ESC’s switch ON. Keep holding full throttle on the transmitter. If all your connections are correct, you will hear one multi-toned initialization “ring” from the motor (all tones are played by the ESC vibrating the motor).
STEP 4: After a second or two, the green LED on the ESC will blink rapidly and the motor will “ring” 4 times rapidly in a row (accepting the full throttle endpoint). After the green LED flashes and tones, the ESC will blink the red LED. At this point the full throttle endpoint has been set within the ESC and now it’s looking for the full brake endpoint (red LED blinking).
STEP 5: Move the throttle trigger to the full brake position and hold full brake. After a few seconds, the ESC will flash the red LED and ring 4 times rapidly (accepting full brake endpoint).
STEP 6: After accepting the full brake endpoint the ESC will then blink the yellow LED. Now relax the trigger to the neutral position. The ESC will now ring 4 times and flash the yellow LED rapidly to accept the neutral position.
