Traxxas SLASH topic
yeah ik ben zonder ook heel te vreden, had de beste high discharge leds van de locale electronica shop dus dat helpt wel een beetje...
OOH en in Het engels omdat ik de post heb geschreven op het URC forum en geen zin heb om hem te vertalen:)
Okay in the tradition of everyone on this forum i'm going to be taking you through my truck and telling you about whats on it, basically it's "look at me spending waaaaay more money on this hobby then i should" But thats okay since i'm pretty positive all of us do it:)
So backslash, widenend rear end with rustler components,
5.5t ezrun geared 15/86, screams bloody murder when i hammer it, might need to gear it a bit higher as that seems to stop the noise and then jangify the rear so i can fit a cooler into there...
Xtreme chassis in g-10 (all props to JT for discovering the look)
Xtreme front and rear shock tower, (the front tower does NOT fit well on the bulkhead, screws to close together)
STRC bulkhead, black
STRC captured hingepins,
Red traxxas ultra shock alu caps.
Stock servo
Ghetto cooler, 2x 30mm coolers i had lying around wired straight into the battery pack, one of them exploded (and i mean that it came apart to non moving components) the other one pushes enough air through to keep it all cool , have a 3s ezrun fan on order so i can replace this when the ghetto rig aspect freaks me out.
Bashed to hell body for a Kyosho mp777 will be ordering a Jconcepts freeflow for the rc8e to take over for that one (I'm thinking white, red, black tribal flames anyone have any ideas, red and black colorscheme)
Ooh and a bunch of loose wires that i need to wire up to become the head and tail light assembly still havent quite worked out where i'm gonna mount those, prolly on the upper deck off to the side of the battery tray to keep it out of the way, maybe i'll hide it underneath not sure yet.
YES i'll get some black electrical tape this is what i had so plz no shooting
Some old 40MHz radio which might be a three channel since theres a switch on it i havent been able to identify yet might need to go and figure that out...
Have some parts on order to make bodymounts and such but something went wrong with the paypal, anyone have a direct email adress for the bloke who runs liquid rc?
And since i used waaaaay to little locktite on the whole thing i am going to pretty much rip it apart again to redo it:)
Unlimited classe backslash:P nooit bedoeld om er als slash uit te zien:)
Hell ik heb hem gekocht om hem om te bouwen. Voor dat iedereen weer "waarom" tegen me gaat gillen OMDAT HET KAN en omdat ik dit er beter uit vind zien!
Ja dat gedeelte van de post was er vanaf gevallen:p op URC stond er bij dat dat off limits was... Ga maandag waarschijnlijk even een rolletje zwart kopen:) misschien rood om bij de rood zwarte theme te passen...
Krimpkous gaat helaas niet lukken omdat het een structureel ding is je kan het er niet naartoe "schuiven"... Als ze krimpkous-tape zouden uitvinden mag die persoon wat mij betreft meteen een nobel krijgen:)
Hmmm tijd om dat eens uit te gaan zoeken dan:) maarja ik moet tog de bedrading nog even af maken en dan kan ik daarna alles wel mooi weg werken:)
dat bestaad volgens mij hoor,heet dacht ik vulkanische tape ofzo.is plakband en bij verwarming krimpt het iets
Vulkaniserende tape.
heeft niets met vulkanen te maken maar deze tape gaat een "verbinding" aan met het andere deel waardoor het een geheel wordt.
veel toegepast in de electro techniek (beschadigde kabels en dergelijken)
Is er iemand met een VXL set in z'n slash die 'm even kan wegen excl wielen en kap? Volgens mij staat het op de Traxxas site met wielen en kap maar uiteraard met de geborstelde set. tnx
Hallo Jongens.
Ik heb vandaag mijn Turnigy 5000Mah lipo mogen onvangen
maar ik heb een vraag
ik wil mijn Slash lager bij de grond hebben waardoor ik dus meer op de weg kan rijden..
weet iemand wat voor shocks ik er dan opkan zetten
juist
  • je haalt je schokbreker uitelkaar
  • er is een metalen stang met een zwart schijfje aan het eind
  • net onder dat zwarte schijfje doe je een stukje brandstofslang van een nitro rc
  • zet het weer in elkaar
dat kan, of een kortere set veren zoals de 2 eb 2.5" van losi, passen prima op de ultrashocks en ik run ze met vrijveel preload omdat ik anders over de grond schuur. dan zak je iets verder door je voeten...
Mocht je het iets profier willen aan pakken raad ik de xtreme chassis enorm aan...
Update, de ledjes zijn bedraad, de printplaat zit onder de servo en de gele tape door zwart...
Sorry voor de double post maar heeft er iemand nog een rechter voor A-ARM of een set? Enige haast is geboden want ik hoopte hem mee te nemen naar lowlands om dan als ik een nacht dienst heb lekker te gaan rammen op het parkeer veld:)
