Vandaag ook jetcat maar even gecontact:
Betreff: P80 RPM problem
Dear Herr Topfer,
i own a jetcat P80 with now a total runtime of 11 minutes (bought it with 8 minutes) and have a problem:
It only reaches an MAX RPM of 86100.
Some info:
V5.1 ECU
MAX rpm is set to 117.000
Learn RC is done correctly
transmitter setting iaw the throttle are set to 100%
All fuel lines and components installed according the manual.
Fuel used: Zibro petroleum with BP2380 Oil
Fuel is new, filters are new.
Start pump voltage is set to 0.2v
S/N 216, built app. 2005, upgraded to V5 ECU in Okt 2007 @ Jetcat germany.
Last run before this problem was performed bij Jetcat.de after upgrade
Info about the last run:
Last max temp was 622,
last min pump was 0,75v
last max pump was 2.00v @ 86100 last max rpm
Last off pump was 0.9v @ 43300 rpm.
I hope you have a suggestion for my problem?
Might a ECU reset to defaults help?
Thank you in advance,
Kind regards, Melvin Damen
En dit is zijn antwoord:
Dear Melvin Damen,
please try to do following procedure:
Start the turbine and set the throttle stick to full and press the button “Maual” on GSU as long as the RPM reach 117000.
If this don’t work let me know the temperature and pump voltage what is shown in the display of GSU.
Best regards
Udo Töpfer
Morgen maar eens proberen! Blijkbaar ga je dan de ecu inleren!
Max power en dan de manual knop indrukken tot de motor doortrekt naar 117k....
Ik ben benieuwd!!!
