Heeft iemand al ervaring met dit hoofdtandwiel, met name de kwaliteit en materiaal sterkte ?????
Erik
[FONT=Verdana,Tahoma,Arial,Helvetica,Sans-serif,sans-serif][/FONT][FONT=Verdana,Tahoma,Arial,Helvetica,Sans-serif,sans-serif][SIZE=-1]
Precision CNC Main Gear 94T - HIROBO Lepton[/SIZE][/FONT]
[FONT=Verdana,Tahoma,Arial,Helvetica,Sans-serif,sans-serif][/FONT][FONT=Verdana,Tahoma,Arial,Helvetica,Sans-serif,sans-serif][SIZE=-2]
Very High Quality Precision Part[/SIZE][/FONT]
[/SIZE][/FONT]
[FONT=Verdana,Tahoma,Arial,Helvetica,Sans-serif,sans-serif][SIZE=-1]The Precision CNC Main Gear is designed to improve the performance over stock main gear. The main purpose of this upgrade is to provide true, round and un-wobbled main gear. The new CNC main gear is produced with better material than stock main gear. This material will make the gear stronger and therefore it is not easy to wobble. It is produced by CNC machines so it is absolutely true and round. Throughout testings to select best material for the main gear, we finally chose this material over our famous BLUE material that we used to make upgrade gears for all of the helicopters. This main gear is a drop in replacement gear for Hirobo Lepton. It is designed to improve performance on the HIROBO Lepton helicopters.[/SIZE][/FONT]
[FONT=Verdana,Tahoma,Arial,Helvetica,Sans-serif,sans-serif][SIZE=-1]15.99[/SIZE][/FONT]
[FONT=Verdana,Tahoma,Arial,Helvetica,Sans-serif,sans-serif][/FONT][FONT=Arial,Helvetica,Geneva,Sans-serif,sans-serif][SIZE=-2]PART#MH-LE5102MG[/SIZE][/FONT]
